do i need 02?
Old Mar 25, 2006 | 08:09 PM
white mongoose's Avatar
Default do i need 02?
im about to receive my headers (pace headers lt) but i dint order my o2 or extension some people r telling that i wont need them , because the car is going to get tune and they r going to cancell the 02 is that true or do i really need them .
Old Mar 25, 2006 | 08:10 PM
X-JeSSter's Avatar
You will either need extensions for your front O2's or you can buy rear o2's for a c5 (bosch 13111) because they have a better heating element and longer wires. You won't need extensions if you use Bosch 13111's, and you are less likely to get a heater circuit trouble code.
The reason for the above is because your front oxygen sensors will be much further away from the motor than they are on stock manifolds.
As for rear O2's, you either need simulators or a computer tune to delete them if you don't want your check engine light coming on.
Old Mar 25, 2006 | 08:25 PM
so i just need my front 02 and no ext
Old Mar 25, 2006 | 08:41 PM
hondo's Avatar
You need extensions to connect YOUR existing front O2's, OR buy Bosch 13111 O2 sensors which already have longer wires on them, that'll take care of the front ...
Your tuner will shut off the REAR O2's in the PCM so you dont have to do anything back there, it will set a code until it's tuned though. You don't need O2 simulators if you are going to get a tune.
Old Mar 25, 2006 | 10:41 PM
scottyk246's Avatar
Couldn't you just lengthen the wires on the original O2 sensors?
Old Mar 25, 2006 | 11:04 PM
2K2WS6TA's Avatar
Yes you can lengthen the wires (the pacesetters come with wire) it's up to you, you can
1 Get vette o2s (bosch 13111s) and not have to make the extensions
2 Use the premade extensions
3 Lengthen the wires yourself using the wire included with the pacesetters
You only need to use one of the above three choices
Old Mar 27, 2006 | 11:04 PM
thanks alot u guys im probably going to get some ext or just buy the bosch13111 what would be better or it really doesnt matter cause i could get the ext. for 40 bucks as far as the bosch have no clue thanks by the way
Old Mar 27, 2006 | 11:30 PM
2K2WS6TA's Avatar
Well the boschs can help with the slow switching codes, that can occur with the stock 02s in LT applications, it's your call, I went with the boschs, and haven't had many codes thrown (only when it's cold outside)
 Michael S. Palmer
Old Mar 28, 2006 | 03:16 PM
2k2ws6 where can i get the bosch, and by the way how much did u get him for thanks alot man
Old Mar 28, 2006 | 03:40 PM
FBDYLVR's Avatar
I'm pretty sure you can get them at Autozone.
Old Mar 28, 2006 | 04:04 PM
2K2WS6TA's Avatar
You can usually get them at most any chain parts store (autozone, oreillys, pep boys, advanced, napa), they go for about $69/ each
Just ask for the corvette rear o2 sensor, bosch p/n 13111
