need pic for catch can install. Install where?
Old Mar 26, 2006 | 03:53 PM
TransAm_00's Avatar
Default need pic for catch can install. Install where?
Could someone please email me a picture of where to install a oil catch can on my ls1. Thank You.
Old Mar 26, 2006 | 04:04 PM
AdamSS's Avatar
Do the search. There has been dozens of threads on that !
Old Mar 26, 2006 | 04:20 PM
Mike02Z's Avatar
Here is my AMW mounted to the passenger side head.
Old Mar 26, 2006 | 05:29 PM
Viper's Avatar
No pic, but next to the fuse box on the driver side, attached by the radiator. Ran the lines under the MAF.
Old Mar 27, 2006 | 09:30 AM
STANG KILLA SS 2's Avatar
Old Mar 27, 2006 | 06:02 PM
Blacker's Avatar
Mike02Z: Aren't the rubber lines connected to the AMW Catchcan reversed? The instructions have the PCV Line connected to the lid and the vacuum source connected to side of the can.
Old Mar 27, 2006 | 06:44 PM
Mike02Z's Avatar
The line comes out of the valve cover goes into the PCV valve and from the PCV it goes into the top of the can. The side line goes into the manifold where the vacuum is being pulled. I believe they are connected the right way and the way you describe.
To be honest I think it would work either way. The oil falls to the bottom and either line pulling vacuum is not going to pull the oil up from the bottom.
Old Mar 27, 2006 | 08:58 PM
Blacker's Avatar
I guess I was looking at it wrong
Old Mar 28, 2006 | 06:43 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
AMW Catch Can - PS shock tower:
Old Mar 28, 2006 | 07:03 AM
Mike02Z's Avatar
Thumbs up
Absolutely stunning 1QUIKWS6. That is the best looking engine compartment I've ever seen!!
Old Mar 28, 2006 | 08:01 AM
227Hawk's Avatar
Dual catch-cans mounted to a 3 point STB.
Hawk
Old Mar 28, 2006 | 08:17 AM
mvonada's Avatar
WS6 your engine is over the top!
Old Mar 28, 2006 | 08:23 AM
1QUIKWS6's Avatar
Thanx guys! Took a lot of $$ and hard work. Actually those are old pics - I'm trying to finish up the new combo prior to car show season - so new pics will be out in a few weeks
Old Mar 28, 2006 | 02:36 PM
JLSain's Avatar
how are you guys connecting your catch cans to the pcv line coming from the block? Can I clip the old PCV Valve holder or should I leave the PCV valve attached and connect the hose from the PCV valve nipple to the catch can inlet?
Old Mar 28, 2006 | 02:53 PM
Blacker's Avatar
I just connect the new hose to the PCV Valve and the other end to the catchcan. I left the PCV in place.
Old Mar 28, 2006 | 03:20 PM
JLSain's Avatar
Is that working out ok? Filling the catch can up ?
Old Mar 28, 2006 | 04:34 PM
Blacker's Avatar
I just dumped out 2 cups of oil and the interval was ~10K miles. My car has never been an oil burner. The hose going to the intake is clean and the TB has remained clean as well. Money well spent.
