5.3 v 5.7 valve cover differences?
I've just gotten the heads installed and torqued down, and set the valve covers in place. I've noticed a couple of differences:
~ The 5.7s have two PCV tubes on the passenger's side while the 5.3s have only one, located on the driver's side
~ The 5.7s have a larger oriface for the oil fill cap, and the 5.3s have a much smaller one (which makes my current breather and/or stock fill neck useless)
So does this mean I have to find the correct 5.3 items if I wanna use these covers, or should I just try to find some 5.7 covers since they already have the correct provisions? This still leaves the problem of missing one of the PCV provisions. I'm just having issues because I've had these 5.3 covers hot tanked, bead blasted, and professionally painted. I obviously didn't see a difference until now.
Thanks
One cover has a large hole, the other a small hole.
Large one = oil fill or breather
Small one = PCV w/ grommet plugs directly into it.
The PCV one runs a line to the other valve cover provision, then "y"s off to the TB like stock.
Pics will come to simplify my explanation.
That, and I'm lazy and it's cold outside :o
