What is this connector for?
Old Jul 18, 2002 | 10:27 AM
COBRA.LS1's Avatar
Default What is this connector for?
I am trying to figure out what plugs into the connector on my 2000 fbody ls1. It is a female connector connected to the oil pan on the driver's side infront of the motor mount. Also have a male connector that is white about 2 inches long with 18 inches of wire with the silver heat coating wrap. Any ideas appreciated.
josh
Old Jul 18, 2002 | 11:25 AM
xssive's Avatar
Default Re: What is this connector for?
Should be the oil level sensor
Old Jul 18, 2002 | 01:55 PM
COBRA.LS1's Avatar
I thought the oil level sens was on the passenger side under the starter.
josh
Old Jul 18, 2002 | 02:05 PM
Phate's Avatar
The white connector sounds like it might be the ABS sensor for that side...
Scott
Old Jul 18, 2002 | 02:15 PM
ASR OFF's Avatar
The connector for the oil level sensor is on the pass. side. I have not ventured over on the driver's side much so I do not know what connector you're talking about. I'm sure someone has access to the book.
