How In The Hell Do You Get The Alternator Off!!!!
Old Mar 26, 2006 | 09:35 AM
HOSS's Avatar
Default How In The Hell Do You Get The Alternator Off!!!!
Someone, please, help?
Old Mar 26, 2006 | 09:38 AM
Steve Burger's Avatar
LS1TECH Sponsor
Pull the belt, unplug the wire connection, disvconnect the battery feed, pull off the 2-3 bolts holding it on and drop from the bottom.
Old Mar 26, 2006 | 09:48 AM
227Hawk's Avatar
The Out-put wire connection nut is loc-tited. It's a bitch.
Hawk
Old Mar 26, 2006 | 10:06 AM
HOSS's Avatar
I figured that one out, i have the 3 bolts out, that bitch is stuck, I have hit it, pryed, I dunno what else to do. I might try and **** on it.
Old Mar 26, 2006 | 10:09 AM
STANG KILLA SS 2's Avatar
there is a 1 small bolt on the BACK side that your forgeting i bet.
Old Mar 26, 2006 | 10:22 AM
LS69TA's Avatar
I've got scars on my hands from those damn manifold heat shields. Too bad I didn't put headers on before replacing it. I thought I was going to have to drop the sway bar to have room to get it out. It just barely slides out once you get it positioned right.
Old Mar 26, 2006 | 03:16 PM
Dmoney's Avatar
Remove the pulley above the alternator to get to the bolt on the alternator bracket and loosen the bolt. That makes it easier to pull and put back the alternator.
