!@#@)(*&!Stripped out fuel pressure test port!!!
Old Jul 23, 2002 | 04:17 AM
Operation BirdBOMB's Avatar
Default !@#@)(*&!Stripped out fuel pressure test port!!!
Friends don't let friends remove schrader valves with screw drivers.
Is there anything I can do to band-aid it up and drive it? I am definitely not buying a new fuel rail. I'm trying to get a FPSS and leave that on the end of the rail. I'm guessing that cap that goes on the end isn't going to be able to hold anything in. What should I do?
Old Jul 23, 2002 | 08:39 AM
Tin Indian's Avatar
Default Re: !@#@)(*&!Stripped out fuel pressure test port!!!
Well, you may be in luck. From what I remember, the schradder valve is made of brass. The soft schradder valve may be stripped, but the steel fuel rail threads may be ok.
Did you buy a new valve and try to install it first?
If the fuel rail inside threads are indeed stripped, you can purchase a blue anodized aluminum AN cap. Sometimes called a "B" Nut in the aviation business. Just screw the AN cap on to the end of the fuel rail. Screws on the fuel rail outer threads just like the little metal cap that originally came off. Earls and Aeroquip sells them through speed shops. I can't remember the AN size though.
Ron,
Old Jul 23, 2002 | 08:42 AM
Tin Indian's Avatar
BTW, those AN caps are sized by number. You may need a #5, but again, I am not real sure on the number size.
Old Jul 23, 2002 | 11:27 AM
JP98SS's Avatar
Just put the plastic cap that used to be on the end of the fuel rail back on...it seals just fine.
Old Jul 24, 2002 | 08:24 PM
Gold Phoenix's Avatar
It's a AN6 cap
