What Should I have done?
Old Mar 27, 2006 | 08:57 AM
Madmax054's Avatar
Question What Should I have done?
I just got Pacesetter LT's and TSP X pipe installed the other day. I have it dumped right now but i want to go out the back cause of the noise and fumes. How should i have them go out the back cause i have the 3 inche pipes?
Old Mar 27, 2006 | 09:13 AM
Gearhead1's Avatar
If you need to reduce the size to 2.5 in, Flowmaster makes a nice reducer. It's about 9 in long and has a very gradual taper to it. http://store.summitracing.com/defaul...h.asp&N=400238 At the top, type in FLO-R3025 for the part number.
Old Mar 27, 2006 | 09:39 AM
02SS0384's Avatar
If you stay with 3" you will have to go under the axel.
Old Mar 27, 2006 | 10:54 AM
Madmax054's Avatar
I went up to meineke and they said they can bend 3" and go over the axle and just add pipe to go out the back. The only reason why im goin out the back is cause fumes are getting in my car pretty badly and thats just bad news lol.
Old Mar 27, 2006 | 11:15 AM
Madmax054's Avatar
My end pipe is hangin about half an inch from the ground also. Should i just stick with what i got and raise the end of the pipe up a little bit cause meineke said they can do that too but what would i do about the fumes? Simply, whats the best thing to do?
Old Mar 27, 2006 | 12:50 PM
TheBlurLS1's Avatar
That's what she said...
You need to put a jack under the dumps and jack them up as high as possible, beating on whatever you need to to get them riding right.
Check out the link in my sig for pics and a writeup. I got my duals sitting purty, then had them run out the back w/ 3" pipe under the axle. Absolutly no problems.
Old Mar 27, 2006 | 02:09 PM
Madmax054's Avatar
So basically just raise the pipes up the best i can. What about the fumes?
Old Mar 27, 2006 | 04:14 PM
JDP's Avatar
JDP
i plan on getting the tsp true duals and i think im just gonig to go to a muffler show that can mandrel bend pipes and have them fab up some tailpipes and run them under the axle and out the back
