How do you know if you have a bad coil pack??
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Someone suggested that might be the problem with the detonation issues I've been having. How would I know if one was bad?
if you had a bad coil pack, most likely something would happen such as there not being enough voltage to throw a spark or something, causing a missfire.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by verbs:
<strong>Someone suggested that might be the problem with the detonation issues I've been having. How would I know if one was bad?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I am getting misfires at times when racing, but only when racing. That being said would that eliminate the possibility of it being a coil pack?
I've never thrown a code for a coil pack ever...to my knowledge.
In auto tap you can check for misfires on a certain cylinder. Find out which one it is and switch the coil to a different cylinder and see if it does the same thing. Do the same thing with the plug and wire. That would be the easiest.
