Where is the Water Temp. Sensor?
Old Jul 26, 2002 | 10:35 PM
SS125's Avatar
Default Where is the Water Temp. Sensor?
I'm thinking of putting a pod on the a-pillar with either an electrical or mechanical water temp guage. My son has both that he bought for a truck he was building and never used. They are the Autometer white face Phantom Guages. On the drivers side of the cylinder head, there is a sensor at the front of the head beside the #1 exhaust port. Is this the water temp sensor? If I change this, I assume this somehow goes through the pcm, is disconnecting the stock sensor going to set off an SES light or something
Old Jul 27, 2002 | 01:07 AM
98SS#2018's Avatar
Default Re: Where is the Water Temp. Sensor?
Thats the sensor, not sure about SES lights however...
Jason
Old Jul 27, 2002 | 07:22 AM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
I've always assumed the fans were turned on/off in response to the ECT,and probably some other functions rely on it as well. For an aftermarket sensor install do a search, I believe folks have installed them in a plug above the starter.
Old Jul 27, 2002 | 10:40 AM
TA_2001's Avatar
The pcm needs that stock sensor to feel good
about itself.. Here is how I installed a after
market water temp sensor and gauge..
http://www.ls1info.com/article.php?sid=217
