how do i recharge my AC?
Old Apr 6, 2005 | 08:17 PM
ApacheDrill's Avatar
Whats AC ?
Old Apr 7, 2005 | 12:26 PM
Mr Incredible's Avatar
I haven't had my 98 Z28 for long and the A/C has blown hot from the beginning. I got a recharge kit and one of the Chilton's Manuals from the parts store and tried to DIY. The darned manual only showed pre-98 pictures. I can't find an (obvious) low-pressure fitting. I found one that the kit will fit on, but it is on the accumulator. The pressure was 150lbs!!!
Was that the correct fitting? Has some other person overcharged it?
Old Apr 7, 2005 | 01:52 PM
SiL3NtXWS6's Avatar
Originally Posted by tboysen00
do you have to remove the ac condensor when doing a cam swap
You don't have to, but it makes things a lot easier. There is a chance of breaking off a fitting while moving the condenser. The lines are expensive and there is a long wait for them.. guess how i know.
Old Apr 8, 2005 | 08:49 PM
Ping King's Avatar
you need to recover whatever refrigerant could be left (probably none)
pull a vacuum on the system...i usually like to pull 400 microns.
static charge the system by weight...the camaro take 1.5 lbs of r-134A.
if the system wont take 1.5 by static charge...turn the AC on...and charge to 1.5 lbs with gas.
Old Apr 8, 2005 | 09:30 PM
00Z28 Camaro's Avatar
Originally Posted by TA_2001
I dont agree with above.. you can trouble shoot
your system for equipment cost less than $25..
found at oriellys and maybe wallmart..
Here is a sheet of trouble shooting tips and
refilling tips.
http://ls1info.com/article.php?sid=233
note: i had system wide open during header install, did not pull vacume , works fine.
I always recharged the A/c myself took a couple minutes . mabey im thinking of something different ..
Old Apr 9, 2005 | 05:43 PM
Ping King's Avatar
theres a differenece between topping it off and starting from scratch.
Old Apr 9, 2005 | 06:03 PM
Originally Posted by ApacheDrill
Whats AC ?
what keeps you alive in August living in florida
Old Apr 9, 2005 | 06:32 PM
Thats why god created T-Tops..
