FLP header banging - not normal...
Old Jul 30, 2002 | 08:20 AM
Shane's Avatar
Default FLP header banging - not normal...
Look, I know about the 'normal' floorboard banging, but this doesn't seem to be the same thing.
I had these same headers on my 99, and had no issues with header to car contact. Now that they're installed on my 02, the header bangs up against the side of the k-member. It's already taken off the coating in that spot, and I'm worried about it actually damaging the header.
I tried to reposition the header this weekend, and was not able to change anything. Does *anyone* have *any* ideas on what I should try? I'd love to get a tubular K-member, but it just isn't in the budget right now...
Thanks in advance,
Shane
Old Jul 30, 2002 | 01:21 PM
Shane's Avatar
Default Re: FLP header banging - not normal...
ttt
Old Jul 30, 2002 | 04:16 PM
WILWAXU's Avatar
Each car is a little different... may want to try a torque strap. It will limited the movment of the motor...
Old Jul 31, 2002 | 01:59 PM
Shane's Avatar
Awesome guys...thanks. I'll check into the torque strap (rachet strap) first, and see if that helps. If not, I'll try the tranny mount... If it still bangs after that, I'll bite the bullet and get the BMR k-member...
<img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Thanks again,
Shane
Old Jul 31, 2002 | 06:31 PM
WILWAXU's Avatar
Here's a good thread on torque straps...
https://ls1tech.com/ubb/cgi-bin/ulti...;f=24;t=000891
Old Aug 1, 2002 | 12:20 AM
2001 Pewter WS6's Avatar
Restricted User
Mine were banging also. I changed the tranny mount with a Poly one from Energy Suspension. No more banging and just a little increase vibration. No much though. The stock mounts are soft and have a lot of movement to them. I am changing the motor mounts soon also.
<small>[ July 31, 2002, 12:21 PM: Message edited by: 2001 Pewter WS6 ]</small>
Old Aug 1, 2002 | 06:13 AM
CMNTMXR57's Avatar
I did the same thing with the Energy Suspension Poly trans mount. I have Grotoyhann's with a 3.5" Y-Pipe, so every time I accelerated, I'd get knock retard from the back of the cat on the drivers side banging the floor.
The poly mount stops all but the hardest clutch mixing from the headers banging.
Old Aug 5, 2002 | 08:23 AM
Shane's Avatar
The "Torque Strap" worked like a charm... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Thanks guys!!!
Shane
 Michael S. Palmer
