P1153 HO2S Insufficient Switching Bank 2 Sensor 1
That is one of the codes I'm getting. I just installed my TTS headers about a 7 weeks ago. I'm tired of the SES light being there so its time to fix it. The codes are:
P1153 H02S Insufficient Switching Bank 2 Sensor 1
P0161 H02S Heater Circuit Bank 2 Sensor 2
Can anyone help decipher these codes? Thanks
The Bull
I got that code before for the inefficient switching. I just moved that O2 to the rear and put the rear in it's place. You may want to try that out first. Also check for leaks. On mine I got a inefficient catalyst error when there was a leak between the O2 sensors.
Hopefully that works, don't go buying up 02 sensors unless you're rich. They're $270 each.
bank, bank2, camaro, censor1, codes, h02s, ho2s, ins, inssufficient, insufficiant, insufficient, ls1, p1153, sensor, switching
