Will I lose power or Noise?
Old Mar 29, 2006 | 02:29 PM
Madmax054's Avatar
Question Will I lose power or Noise?
I have the TSP True Dual Set up with Pacesetter LT's and Sweet Thunders. Will I lose power goin or tone/noise goin over the axle and out the back?
Old Mar 29, 2006 | 02:33 PM
~JOSHUA's Avatar
You will actually gain low/midrange torque and hp. And you'll lose some noise. The top end will peak a hundred or two lower rpm, but the power loss at peak (if any) will be more than made up for by the extra bump down low.
Old Mar 29, 2006 | 03:50 PM
mvonada's Avatar
Firehawk, sweet engine!!
Old Mar 29, 2006 | 03:57 PM
JDP's Avatar
JDP
i dont know if you will be able to run the pipes over the axle and out the back, 3 inch is to big people say, correct m if im wrong or somebody has done it
Old Mar 29, 2006 | 04:06 PM
99camarols1m6's Avatar
if you get the BMR panhard rod relocation kit it is possible and much easier
Old Mar 29, 2006 | 05:23 PM
~JOSHUA's Avatar
Thanks!!!
Old Mar 29, 2006 | 05:25 PM
Shallow Bay's Avatar
will 2.5 inch pipe fit?
Old Mar 29, 2006 | 05:43 PM
WhiteKnightZ28's Avatar
Tech Resident
Hey madmax, how do you like that settup? I ask because thats exactly what I'm planning on buying in a day or two.
Old Mar 29, 2006 | 06:15 PM
JDP's Avatar
JDP
ya, ive heard of 2.5inch pipe going over the axles.
why dont you jus run 3 inch under the axle and out the back, thats what i plan on doing if i go true duals, its simpler and cheaper.
seems like if its done right people have good ground clearance
Old Mar 31, 2006 | 12:48 AM
Madmax054's Avatar
Im having ground clearance issues other wise i would and this guy can bend the 3inch pipes and said he can make it work goin over the axle.
Old Mar 31, 2006 | 02:58 PM
magius231's Avatar
i seriously doubt you will gain or lose either way running 3" pipes over or under the axle, the exhaust is already way too big for the car. I just had it done, no difference in performance, however the interior resonance was drastically cut while maintaining the nice roar on the outside
Old Mar 31, 2006 | 04:38 PM
4.6gt-2-ls1ta's Avatar
you could do under axle and not have a big ground clearance difference from not having the tails. I went under 3in and don't have any clearance issues. also cats will tone down the sound also and shouldn't make a power loss problem.
