Need wiring help for inline fuel pump
Old Aug 2, 2002 | 03:54 PM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
Default Need wiring help for inline fuel pump
What wires can i splice into on the fuel pump connector box?
Old Aug 2, 2002 | 07:05 PM
MIGHTYMOUSE's Avatar
Default Re: Need wiring help for inline fuel pump
to get the most voltage to the pump. splice into the grey wire going to the in tank pump, add a wire and run that to the switch side of a 30 amp relay. then run a ground from the relay to ground
run a wire from the - on the pump to ground. run a wire from the battery to the 12v in side of the relay, run wire from the 12 volt out side to the + side of the pump
i think that covers it.
while you are at it i would run a second power wire from the battery and add another relay to your stock pump wiring so that that one gets 13+ volts as well instead of the stock regulated 12v.
