Quick help on removing intake
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Removing the EGR will get you an SES code, as will removing AIR, even if you leave the pump plugged in and able to run. It's got a back pressure sensor that tells the computer that the pump is still connected to the system.
The metal part left over sticking out of the block is the part that has the hex-head on it that the socket grabs. Only the top (plastic) piece breaks off.
