asp pulleys
Old Aug 6, 2002 | 11:55 PM
johnster's Avatar
Default asp pulleys
I got the asp pull kit.It has two pulleys in it.Will is keep charge?The alternator pulley is a little smaller than the stock one. I need part numbers on the belts.If anybodys got them. Thanks
Old Aug 7, 2002 | 07:38 PM
WILWAXU's Avatar
Default Re: asp pulleys
What transmission do you have?
Old Aug 7, 2002 | 10:25 PM
justin sutton's Avatar
He has an a4 trans.
Old Aug 8, 2002 | 07:24 PM
mike c.'s Avatar
on an a4 use the crank pulley only,this way you dont have charging problems.the 6 speeds idle higher and can use both. i gained 1.5 tenths on crank only. good luck.
Old Aug 9, 2002 | 02:14 PM
Larry's Avatar
If you have a smaller alternator pulley than stock then you have an overdrive alternator pulley. It will charge better than with just a crank only pulley system. Most alternator pulleys are larger than stock. It will charge better than a stock alternator pulely but you won't get quite the hp gains.
Old Aug 9, 2002 | 10:21 PM
MY99TAWS6's Avatar
asp lists the belts on their site but their is an error in the size if you have an overdrive alt pulley..the overdrive is smaller than stock,the underdrive alt is bigger..gates was ko60755 I think..the ko60760 is just underdrive crank pulley and ko60770 is with underdrive crank and underdrive pulley..the asp instructions are wrong for the overdrive pulley..I emailed them and they confirmed this..makes sense as smaller overdrive alt will take a smaller belt.The air belt is same with all the pulleys..forget the number but is on the asp website and you should have got some piece of paper with the pulleys..remember use a new bolt and put blue loctite on the pulleys..mine seems to be working great.
Old Sep 4, 2002 | 01:38 AM
JTM's Avatar
JTM
So the ASP Pulley I need for my A4 is the 25% REDUCTION CRANK PULLEY from ls1speed.com for $189, and I can expect a .1 maybe?
