Installing spark plugs..& oil on threads?
Old Aug 7, 2002 | 08:46 PM
2000 Camaro SS's Avatar
Default Installing spark plugs..& oil on threads?
When I put in my spark plugs I tighten them very lightly. I use very little pressure. Would this be a reason I have some oil blow by that goes up into the threads? I have the same problem as this post as far as the oil on the threads go.
https://ls1tech.com/ubb/cgi-bin/ulti...=006656#000002
I also shoot nitrous I'm wondering if I am getting blow by if there is HP being lost there also. What do you think?
Old Aug 8, 2002 | 01:35 AM
Bad1le's Avatar
Default Re: Installing spark plugs..& oil on threads?
Rings are prolly shot, not an uncommon problem <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
AJ
Old Aug 8, 2002 | 05:30 AM
wizkid's Avatar
Install Director
Hard to gauge by those pictures. Mine have a just a little fuel/oil (something) on them when I change them but nothing I fret over.
Do you consider it to be a lot of oil on them?
Moving this to the internal section where you can get some better responses to this.
Eric
