FAST intake install problem
Old Apr 1, 2006 | 11:57 AM
Formula_Power's Avatar
Default FAST intake install problem
I am in the process of installing a 78mm fast intake on my bird....and i have notice some things that are pising me off....the biggestest thing is when i compared the fast intake to the ls1 intake the ls1 intake has 2 brass inserts in 2 of the hole that bolt the manifold down...they look to be used to level the manidol on the motor and there are grooves in the heads for them to mate with....well my new fast intake does not have the inserts and the ones in the ls1 intake won;t fit....has anyone ran into this problem before??
thanks
DUstin
Old Apr 1, 2006 | 02:14 PM
Default ttt
anyone?
Old Apr 3, 2006 | 12:41 PM
WILWAXU's Avatar
to the top
Old Apr 3, 2006 | 12:57 PM
DanZ28's Avatar
Mine lined up fine without the brass inserts (there not used in the FAST). I didn't see it as a problem, does yours not line up? have you tried it yet? Or you just pissed because they didn't put them there like the LS1 piece has? Just trying to understand exactly what the "install problem" is.
Dan
