help with 160 thermostat please!!!
Old Mar 29, 2006 | 11:42 PM
99camarols1m6's Avatar
Default help with 160 thermostat please!!!
i just ordered an slp 160 thermostat installed it and filled everything back up and it is still running at the stock temp. i know that the fans dont engage untill 215 but i took it for a drive (temp is like 45 outside) and it stayed at 195. then when i got home and let it sit for like 1 minute it was at 210. is it stuck, defective, or is there an instalation trick or what. by the way does the slp thermostat say MotoRad Germany at the top??? just wonderin if WS6 store sent me the wrong one. Thanks, chase
Old Mar 29, 2006 | 11:45 PM
Camaro99SS's Avatar
The 99's and up are just dummy guages that read about 210 even if the coolant temperature is 170. I hooked up a scanner to mine, and when it was 173, the guage read right around 200 which was what it read with the stock thermostat.
Jason
Old Mar 29, 2006 | 11:50 PM
kool thanks, so like an aftermarket autometer gauge will give some exact readings. i thought i did somethin wrong. oh and the slp thermostats arent actually made by slp i take it??? cause at the top of mine it says motorad germany... just wonderin
Old Mar 29, 2006 | 11:53 PM
Camaro99SS's Avatar
Yeah an aftermarket guage will give accurate readings. I'm not sure who makes the thermostat. It could just be made for them to their specs by someone else.
Jason
Old Mar 29, 2006 | 11:58 PM
yeah thats what i was thinking about the thermostat... thanks for the help oh and by the way how do you like your lanes true dual setup, cause duals and longtubes are my next purchase...
Old Mar 30, 2006 | 09:40 AM
parbreak's Avatar
Mine says MotoRad Germany also.
Old Mar 30, 2006 | 09:50 AM
kanewolf's Avatar
Mine is the same way. I was pissed until I heard about the gauge myself. Just know that that t'stat will open faster.
p.s. do you have the HypertechIII programmer? (or similar) because you need to let the computer know that you have the 160 t'stat, it'll help the function.
Old Mar 30, 2006 | 03:23 PM
no i dont have the programer but im takin it to force fed so they can make the fans come on at like 140 degrees and im sure they can program the pcm for a 160 thermo as well.
Old Mar 30, 2006 | 05:37 PM
WiseguyZ28's Avatar
figured i'd throw this into here instead of startin a new thread about Tstat's.....But i'm going to be changin my coolant soon..and figured i'd throw in the 160 Thermostat as well. I know it's good to tune the PCM but would not having one mess anything up? I will probably get the tune in a couple weeks or another month...but i wanted to go ahead and put the Tstat in now.
Is that ok to do?
Old Mar 30, 2006 | 05:42 PM
radz's Avatar
You should be fine WISEGUY just make sure you have the fans set as well when the tune is done.
Old Mar 30, 2006 | 05:46 PM
WiseguyZ28's Avatar
A wiseguy makes sure of things he doesnt know....if u were tryin to make a joke of that? i dont know....i think u were tryin to? But sounds good.....hopefully i can get around to it tomorrow. And thanks for the quick answer.
Old Mar 30, 2006 | 06:29 PM
what would happen if you just didnt have a thermostat, i mean still have the houseing and everything but no internals... just a strait thru pipe? my buddy has this on his 5.0 just wonderin if it would mess things up...
Old Mar 30, 2006 | 07:40 PM
kanewolf's Avatar
I strongly recommend against that. You run the possibility of getting the engine too cool, or too hot. The t'stat is a regulator. It knows when the best time to introduce coolant and when not to. If you remove it, your flow would be constant. That's not what you want, because your fluid would get very hot as a result. It needs the radiator to cool it off, so w/o a t'stat, the coolant might pass through the important areas @ too high of a rate. All the while passing through the rady too quickly. It needs the stagnation period to cool effectively. As I mentioned earlier, I have both the 160 degree t'stat and a HypertechIII programmer. I do feel that both are neccessary eventually.
While I'm at it, I'll respond to some other questions here (anyone feel free to correct me)
Not having the PCM knowing that you installed a new T'stat is entirely critical, however, as for the fans.....You definitely will want them to know to turn on more in the near future. You can purchase a switch from www.jegs.com to do this very function w/o having a programmer.
I always recommend a true hardwire switch like that if someone doesn't have a programmer. Because even if your shop can program your set up at that time, you'll be reliant on them anytime you make another change to your system. A switch and/or a programmer will ensure that you can always keep that fan function active, regarless of changes or surges, etc.....
Old Mar 30, 2006 | 07:51 PM
FUN LS1's Avatar
140 is too low; try setting them to
ON = 185
OFF = 175
Old Mar 30, 2006 | 08:05 PM
radz's Avatar
NO jokes wiseguy, just didnt feel like quoteing you. Better to ask and know than just guess.
Old Mar 30, 2006 | 11:30 PM
ON = 185
OFF = 175
On my old car i had my elctric fan wired up to an ignition switch so when the ignition was on the fans would come on and it regulated the temp perfectly... it takes a little longer to warm up but thats it... i dont see how a lower temp fan setting would be wrong
Old Mar 31, 2006 | 07:21 PM
FUN LS1's Avatar
I personally would not want my fans running 100% of the time, and certainly not during winter start-ups. I still get all the benfit of the cooler stat, and my fans get some down time like they're supposed to. Just my opinion...
Old Mar 31, 2006 | 07:28 PM
black00TA's Avatar
the thermostat HOUSING says motorad germany. the thermostat itself maybe not be the same.
mine says the same and its hypertech. i didnt notice much of a difference in the gauge, but i can tell it runs cooler.
Old Apr 1, 2006 | 09:52 AM
kanewolf's Avatar
I don't want my fans to run all the time either.
With the swith I mentioned earlier or the use of a programmer, they will stay on a lot, but not all the time
Old Apr 1, 2006 | 10:49 AM
ashade98's Avatar
Keith @ Force Fed is sort of a donkeys behind. I had a clutch put in there, and many friends have used them. Some of the guys that work there (Bill, if he still does) are great! Somehow, he always seems to find a way to charge ya a little more, and tell ya something you don't want to hear. KNOW IT ALL
So just BEWARE!
