ARP Header Studs??? Really Worth It???
Old Apr 1, 2006 | 03:58 PM
99camarols1m6's Avatar
Default ARP Header Studs??? Really Worth It???
anyone have these??? Just wondering if the ARP header stud kit is really worth like 96 bucks... i heard that it makes instalation much easier, just wanted an opinion on them.
-chase
Old Apr 1, 2006 | 04:08 PM
NHRATA01's Avatar
I couldn't get them to work on mine, though the TTS's I have have very thick flanges. But there just wasn't enough room to thread in the studs, and slide the flange over. I tried putting them in place, and then threading the stud through the flange, but it was too much of a PITA so I just tossed them.
Old Apr 1, 2006 | 04:09 PM
thanks... so pretty much not worth 100 bucks i guess
Old Apr 1, 2006 | 04:29 PM
ashade98's Avatar
I got the breslin split locks. They're badass (so far, 100mi), bout 1/2 the price.
Old Apr 1, 2006 | 05:53 PM
Shallow Bay's Avatar
Or better yet you could buy some new stock bolts for less than $20 shipped.
Old Apr 2, 2006 | 08:27 AM
DarkFormula's Avatar
I still use my stock bolts, as do most of my friends. The extra $$$ could be better spent on something else.
Old Apr 2, 2006 | 08:48 AM
mvonada's Avatar
Your stock bolts for the LS1 is all you need.
Old Apr 2, 2006 | 12:31 PM
Ping King's Avatar
i use them on my turbo car...its a lot easier to put the headers in and stripping the heads out is a lot harder.
Old Apr 2, 2006 | 12:43 PM
ShevrolayZ28's Avatar
The Breslins look nice but over $5 per bolt(stainless steel) - yikes!
If you are using the stock bolts, make sure they are not too long. Some header brands use a thiner flange and as a result the stock bolts thread farther into the head. This could create problems IMO, like stripped threads, broken bolts, and poor sealing!
Also, it is very important to clean the bolt holes, and if you reuse the stock bolts, make sure they are perfectly clean as well. Use the proper thread dressing before reinstallation.
Before you apply thread dressing, do a dry run, the bolt should thread right in there without resistance. Take your time. You do not want to bugger up the threads or snap one off!
Old Apr 2, 2006 | 06:37 PM
davered00ss's Avatar
Moderator
Get the stage * locking bolts. Kooks come with new bolts that work great. I just did 2 sets of headers with friends. One with the bolts that came with the Kooks headers and the other with the ARP header studs. the studs were a pain in the ***. I had to remove the front ones to get the header up into place. The rear bolt was harder than the header stud. But I would go with the bolts if I had to chose.
