SLP LTs and cut-out questions????
My question is... is there enough room to put cutouts in the o/r pipes? (so I can basically run open headers). Also... is there enough room to then put on McCord's Power Plate cut-out under there??? please remember I'm wanting to put them into the o/r pipes, not knowing how tight of fit it is where the headers end and the pipes would be
Thanks in advance,
Troy
<small>[ August 11, 2002, 03:00 PM: Message edited by: TK 14 SS ]</small>
In other words, you should have the space to do it as far as the headers are concerned; but to be honest, ground/chassis clearance could be an issue.
i really wouldnt run cutouts that close to the header anyway unless you have a heads/cam package to make up for no backpressure. Just my 2 cents
