Fuel Pressure dropping to 45psi...
Old Aug 13, 2002 | 05:06 AM
Chris99WS6PWTMET's Avatar
Default Fuel Pressure dropping to 45psi...
After doing a search here I come up with our LS1 FP being a constant 58-60psi, with a 2-3 psi drop at WOT. My fuel pressure is dropping down to 45 psi at the top of each gear at WOT and my injectors are way over 100% DS.
Anyone else have this problem? I'm assuming is either a restriction in the lines or a bad pump. Any info would be appreciated. Thanks.
Old Aug 13, 2002 | 02:12 PM
JoSeY's Avatar
Default Re: Fuel Pressure dropping to 45psi...
I'm thinking dirty fuel filter/bad pump for the pressure problem...
The injectors are maxed out cause the computer is trying to get the A/F ratio correct and injector control is pretty much it's only way of richening up the mixture.
Old Aug 14, 2002 | 12:01 AM
2000 Camaro SS's Avatar
Is your car stock? How about the fuel filter? is it dirty? This would explain the low fuel pressure but I can't tell you whats up with the injectors.
<small>[ August 13, 2002, 12:02 PM: Message edited by: 2000 Camaro SS ]</small>
