LS6 intake install......now idle trouble!
The car is also running hotter now. I am guessing because there is air in the system from doing the crossovers. I figured out how to bleed the system and will do that today, but I still dont get the idle problem. Any ideas?
<small>[ August 13, 2002, 10:51 AM: Message edited by: NataSS Inc ]</small>
- Wires from knock sensors (or other wires) pinched under the intake somewhere
- Loose intake bolts (careful not to overtighten either)
<strong>Oh yeah....did you remember to plug in the vacuum connection and MAP sensor in the rear of the intake?
Todd</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes I made sure that was in
I also noticed a very small fuel leak at the schrader valve......have no idea what is causing that.
You may need to pull the intake again to do this. I am not sure if there is enough room under the cowl to do it on the car. When this happend to me last time, I just pulled the intake again to make sure it was done properly. My car did the same thing, so I am pretty sure thats your problem..
Josh
AJ
Good luck. Let me know what works for you.
GregM
Also, I custom did fit my EGR in with the adaptor that Lingenfelter sells. I JB Welded it in, so I don't foresee it leaking anytime in the near future. The plenum itself will crack before that seal breaks. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
