SES light turned off??!!!!
Old Aug 14, 2002 | 05:04 AM
rockls1's Avatar
Default SES light turned off??!!!!
About 2 months ago or so, I had installed a cam 222/226 112,rods,springs. When I got the car back, the shop where I installed it at told me that my SES light would stay on because of a random misfire code that would be thrown with the computer. So like he said it stayed on. After a while the car seemed to be runing really rich, and not performing as I expected. Well As time passed, the car seemed to be perfoming a little better. About a week ago, I took off my K&N filter to clean it, Dumba$$ me forgot to put it on, and drove off. After I realized this, I pulled into K-mart and bought a fram to put in. Well a couple days later, with the fram, the light turned off, and the car runs hella lot better. Is this normal? Did the car finally adjust to the change? I know this is kinda internal but I was just curious? Thanks Rockls1 <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Aug 14, 2002 | 08:30 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Default Re: SES light turned off??!!!!
Maybe the K&N was very dirty and not letting enough air pass?
Old Aug 14, 2002 | 11:55 PM
rockls1's Avatar
Anyone else with an opinion???
Old Aug 15, 2002 | 08:50 AM
Richie Carbone's Avatar
BADA BING BADA BOOM!!!!!!
The SES light will come back on after few more ignition cycles. You need to have the random misfire code turned off in the PCM. Not a big deal.
Old Aug 15, 2002 | 10:19 AM
NoGo's Avatar
IMO it is best not to turn off the random misfire code, but to tune out of it.
If you raise your idle, dial in your IAC's, and play with your low rpm timing, then you will no longer set the P03 code.
Certain SES lights will turn off after a given number of driving cycles. Running without your air filter may have temporarily lowered your IAC count(more air coming in for your current idle rpm) giving your car a better idle. If you had this better idle (read, no misfires) for a certain number driving cycles, the SES may clear on its own.
Old Aug 15, 2002 | 06:47 PM
WILWAXU's Avatar
Moving to the Computer Diagnostic & Tuning section.
