Oil filler neck question?
Old Aug 14, 2002 | 08:11 AM
LS1pilot's Avatar
Default Oil filler neck question?
How does the oil filler neck come off the valve cover? I'm talking about the plastic angle neck attached to the valve cover. I tried twisting it but do not want to break it if it is not a twist-on. It is pretty tight.
I have a BMR strut tower brace and there is no room for an oil breather so I figure I can remove the filler neck and put a breather on...
Old Aug 14, 2002 | 02:29 PM
cobray's Avatar
Default Re: Oil filler neck question?
Turn it 180 degrees counter clockwise, then it will pull right off.
It is a little tight, but it will come off with a little pressure. I used some plyers to get it to move initially.
