MSD fuelpump
Old Aug 14, 2002 | 02:21 PM
BadAssY2KTA's Avatar
Default MSD fuelpump
yeah i was wondering if this fuel pump would work on our cars and if it is as good as the Warlboro?
MSD High Pressure Electric Fuel Pump
Multiport EFI systems require a stable fuel supply to maintain best performance throughout the engine’s rpm range. This high pressure and high flow Fuel Pump features a roller vane pump mechanism which is extremely resistant to clogging and jamming. The pump mounts in-line (out of the fuel tank) with two supplied cushioned clamps for a quick and sturdy installation. The nipple inlet is 3/8” with a 5/16” outlet. The wire terminals feature brass studs for secure connections. Made in the USA, the pump is ideal for use as a “booster” for nitrous oxide applications, or as a stand alone pump for multiport EFI systems on engines up to approximately 500 HP. Capable of 43 gph at 40 psi/162l/h.
PN 2225
