GReddy oil catch can idea.
Old Aug 17, 2002 | 08:02 AM
DARK AGE 53's Avatar
Default GReddy oil catch can idea.
I'm starting to see more and more guys using this catch can so I thought I'd pass along an idea. Buy some green 3-M sanding pads ( not sure if that's the proper name for it ), cut it to fit the inside of the catch can. The pads should trap the oil and make the can fuction better, I think about two inches of the 3-M pad at the bottom of the catch can should work great. JMO
Al
P.S. Scotch-Brite pads would work also and there cheap, once the pads become too saturated with oil you can just install some fresh pads.
<small>[ August 17, 2002, 11:04 AM: Message edited by: DARK AGE 53 ]</small>
