Throttle body
Old Aug 17, 2002 | 09:54 PM
2000 Camaro SS's Avatar
Default Throttle body
What do the two holes do in the throttle body? I would like to understand there function before I epoxy them and port the throttle body.
Old Aug 17, 2002 | 10:38 PM
JPR's Avatar
JPR
Default Re: Throttle body
With the TB front opening facing you, the top left hole is for the crank case secondary ventalation, (mainly under WOT) the second hole to the top right is for the IAC motor.
Old Aug 17, 2002 | 10:45 PM
So is there a size limit to retain?
Old Aug 19, 2002 | 11:09 AM
SStrokerAce's Avatar
Kind of. You need to keep them big enough so the IAC works properly. The PCV is just an emmissions thing.
Bret
Old Aug 20, 2002 | 07:45 AM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
I started at about 1/4" and eventually ended up roughly 3/8" or slighly less for the IAC inlet. Going up in size made my idle less "surgy" on startup, however it's always been a little unstable since the TC install. Actually, it now idles better than it did before epoxying the TB.
Also if you go a little small (on the IAC inlet) you may hear a weird noise when first cranked-this will be the IAC motor making a "radical" adjustment as the pcm figures out where it wants it to be.
Also I found that regular epoxy works fine, but I notice some like the "metal" type like Devcon.
