Stock Throttle Body...
Old Aug 18, 2002 | 05:48 AM
Norm's Avatar
Default Stock Throttle Body...
How big in mm is an '01 TA throttle body? What would be a good size to upgrade to? Thanks.
<small>[ August 18, 2002, 05:49 AM: Message edited by: Norm ]</small>
Old Aug 18, 2002 | 06:33 PM
Jantzer98SS's Avatar
Default Re: Stock Throttle Body...
The stock TB is 75 mm at the blade, but necks down to 70mm. The inlet on the manifold is around 75mm so a ported stock TB is the way to go.
You can see pictures of stock & ported on my webshots page.
http://community.webshots.com/user/jantzer98ss
Old Aug 18, 2002 | 06:44 PM
CorsicaLT1's Avatar
Where can I find all stock TB specs for 98-02? (Mainly mm sizes) Also, where can I find out how to port & polish my own? I tried Install U, but I didn't see it there.
Old Aug 19, 2002 | 12:16 AM
99 Black Bird T/A's Avatar
I think they are 70mm
A ported TB was worth 3rwhp and 5 rwtq on my bolt on car. LPE did mine, it was smoother inside, the blade shaft and been cut down a good bit and the LPE opened all the way. For the cost I've very happy with it.
This was before Shaner and Jantzer, started offering their ported TB's. If I didn't have a ported TB I'd read up and try either Shaners or Jantzers.
I don't think there is much if any value in a bigger TB compared to a stock ported one for a 346 displacement engine. Most of what I've read about the BBK 80mm is negative. The opening in the LS1/LS6 intake is about 70mm so I don't see how the BBK is really going to gain much.
<small>[ August 18, 2002, 12:17 PM: Message edited by: 99 Black Bird T/A ]</small>
