fuel pump & regulator question
Old Aug 20, 2002 | 09:20 PM
TUFFLS1's Avatar
Default fuel pump & regulator question
I am trying to figure out the way i what to go with my fuel system i have gone through the whole motor and i know my car needs a better fuel system i here guys putting in inline pumps with the stock one is that the way to go or put in a new fuel system with return line and one more question i have a 99 they say the fuel reglator is in the tank but what is that silver thing that looks like a reglator on the fuel rail need some options thanks
Old Aug 22, 2002 | 11:44 AM
Sparky's Avatar
Default Re: fuel pump & regulator question
I'm also thinking about going with a return system with a an external regulator on my '99. 3 options:
1: New intank pump
2: External pump
3: Custom return system with new intank pump.
What you see on the fuel rail of a '99 is a damper, it is not the regulator.
Mark
Old Aug 23, 2002 | 09:35 AM
MIGHTYMOUSE's Avatar
an 255 inline is very noisy, and will not flow as much when impeded by your stock pump as one 255 in tank
it would be a good idea while you are in there to remove the stock regulator and add an aftermarket one in the stock return line going back to the tank.
