AC fluid amount?
Old Aug 21, 2002 | 05:23 AM
99 TA's Avatar
Default AC fluid amount?
Well I finally got my ac back in and together but I don't know how much fluid to add. A buddy of mine said to add around 35 to 40 ounces of R134a. Is this true?
Old Aug 21, 2002 | 05:57 AM
jmX's Avatar
jmX
Default Re: AC fluid amount?
mine was happy after about 28 oz. after the AC runs for 3 minutes on high, you want your low-side pressure to be around 42-45psi. get a cheap guage and just check it after each can. Dont overfill.
Old Aug 21, 2002 | 06:37 AM
99 TA's Avatar
My friend sucked all the fluid out with a vacuum pump and we added about 38oz including oil. I can't remember the low side, but the high side pressure was around 240 psi. I was thinking that the low side was below 50 psi but can't remember. Thanks for the help.
Old Aug 21, 2002 | 07:17 AM
TA_2001's Avatar
Here is some AC diagnostic info
http://www.ls1info.com/article.php?sid=233
here is the cheap gauge setup that
JMX speaks of
http://ls1info.com/friggauge.jpg
coffee <img border="0" alt="[chug]" title="" src="graemlins/gr_chug.gif" />
