My LS6 Intake Dyno Gains
wow.
I can't believe that is all from the intake. That is just insane. I'll post my results in a few days of my LS6 over the H/L (unported) I just replaced. The holley got me about 3 rwhp on the install, basically nothing, so it should be a good comparison between the 3.
We have the same cam (got mine in the same place) except I have mid-lengths and a M6.
I have a intake (ZO6) waiting to go in.
<img src="http://www.jailhouse-diary.com/bmdyno.jpg" alt=" - " />
<small>[ August 27, 2002, 10:37 AM: Message edited by: mrb00formula ]</small>
I guess my hp numbers are in the ballpark then...
How much does tire pressure affect dyno numbers?
I forgot to inflate my nittos and dynnoed with them at approx. 24psi.
The high torque is because your converter is unlocked. That also causes lower hp numbers than when you have it locked. If you locked it up it would probably give you another 10-15 rwhp.
