RPM Problems
Old Aug 24, 2002 | 08:59 PM
al's Avatar
al
Default RPM Problems
After I installed my electric cut out somtimes my RPMs are higher than normal. It usually happens (example) after I exit the freeway and coast to a light and when I throw it into neutral and stop my RPMs hang around 1200 and 1300. Also when I gear down it donen`t pull back on the motor and slow me down as fast as it use to. What I have been doing is when the RPMs are high I put it in first and let out on the clutch until the RPMs drop. I don`t think that this is hurting my car in any way but I just want to know whats going on with my RPMs. BTW my cut out is right behind the passanger back on stock exhaust. Thanks for any help.
Old Aug 25, 2002 | 07:18 PM
WILWAXU's Avatar
Default Re: RPM Problems
That is a common problem on M6's.. I'm sure someone will chim in. It's not due to the eletric cutout.
Old Sep 4, 2002 | 03:44 PM
WILWAXU's Avatar
ttt
