ls6 intake manifold
Old Aug 25, 2002 | 09:44 PM
marcus's Avatar
Default ls6 intake manifold
hey guys im new to camaro's...and here is my question...is the ls6 intake manifold worth the $450..and how much h.p. is it going to give me? and is the z06 maf worth buying..and how much h.p. is it worth...well thanks for any advice.... <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Aug 25, 2002 | 09:47 PM
VIP1's Avatar
Copy & Paste Moderator
Default Re: ls6 intake manifold
What year Camaro do you have? 2001 and 2002 f-bodies already have the LS6 intake.
--VIP1
Old Aug 25, 2002 | 09:53 PM
marcus's Avatar
i have a 2000 Z28 w/ auto..
Old Aug 25, 2002 | 10:54 PM
CMNTMXR57's Avatar
If you have a heads and cammed engine, yes!
If you have a stock or bolt on modded engine, no.
Old Aug 26, 2002 | 11:29 AM
gator's 99TA's Avatar
it is a great mod if you have atleast a bigger cam in your motor. you can also buy one new with teh coolant pipes and plugs for 420 shipped from SLP. JFYI
Old Aug 26, 2002 | 02:02 PM
yes you can get it without the egr. it is just a replacement intake for 2001-present vettes. and ET is tuff to say but an easy 10RWHP on head and cam cars.
Old Aug 27, 2002 | 12:25 AM
Dr. Jeckel's Avatar
What kinda e.t. gains can i expect from this mod? mods are in the sig. Can you get the intake without the egr from slp? Thanks, James.
Old Aug 27, 2002 | 02:48 PM
BLUEBYU's Avatar
Just installed the LS6 intake from SLP (non-egr w/ help of LS1 edit) shipped to my door $420 (delivered in less than 2 wks!) I have the TR224 and feel a sotp of 15 to 20 rwhp. I did also install SVO 30# injectors while doing the intake swap, which decreased my duty numbers considerably. BTW, it is great reason also to paint the intake.
Old Sep 17, 2002 | 11:07 PM
kaleido's Avatar
The 01 and 02 Camaro does NOT have the LS6 intake. It has the identical c5 engine (except maybe the cam), but it has no LS6 parts. If you want an aftermarket intake manifold, you may as well get either the Holley or SLP unit. And don't expect insane gains in your 1/4 time. In ideal conditions, you'll maybe grab another .3
Old Sep 17, 2002 | 11:31 PM
taqwache's Avatar
well from my understanding, GM desinged the intake for the 1s6 engine and just put it on all 2001 and 2002 camaros and corvettes. this is why everyone calls it the ls6 intake when it should be called 2001 and up intake (just my opinion). on the holley intake, i would say not to get it. i already met 3 people that installed and removed it shortly because they dont release heat very good causeing a loss of power over an 2001 and up intake due to higher incoming air temp's. the way i see it, the stock 2001 and up intake has already proven to 9 second ets. so unless you plan on going faster then that, i would buy it for sure.
Old Sep 18, 2002 | 10:28 AM
WicketMike's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by kaleido:
<strong>The 01 and 02 Camaro does NOT have the LS6 intake. It has the identical c5 engine (except maybe the cam), but it has no LS6 parts. If you want an aftermarket intake manifold, you may as well get either the Holley or SLP unit. And don't expect insane gains in your 1/4 time. In ideal conditions, you'll maybe grab another .3</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">what??
the 01 and 02 fbodys have the LS6 intake and the slp unit is o.e. , its not a slp product that they make. and i really doubt you will gain .3 in 1/4
Old Sep 18, 2002 | 01:53 PM
BlackHawk's Avatar
<strong>The 01 and 02 Camaro does NOT have the LS6 intake. It has the identical c5 engine (except maybe the cam), but it has no LS6 parts. If you want an aftermarket intake manifold, you may as well get either the Holley or SLP unit. And don't expect insane gains in your 1/4 time. In ideal conditions, you'll maybe grab another .3</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Incorrect!
The 01 and 02 LS1's (including the C5) DO already have the ZO6 intake manifold.
It is those of us with '00 and earlier models that need to upgrade at some point.
<small>[ September 18, 2002, 01:56 PM: Message edited by: BlackHawk ]</small>
