HELP!!!!
Old Sep 16, 2002 | 09:24 PM
BigRay77's Avatar
Default HELP!!!!
i need some info guys...my car is surging under heavy acceleration.... <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> ....i bought my car used so i am not sure what all has been done ebfore but i know there has been something to the EGR there is an extra set of wires and plug coming out of it...not professional looking...not only is it doing this but for some reason over the past few weeks when i am in third gear sometimes it pops out! fast or slow it happens once every few days the shifter just comes out to neutral...
HELP!!! thanks guys
Old Sep 16, 2002 | 09:56 PM
BensZ28's Avatar
Default Re: HELP!!!!
I dont know about any of the other stuff, but the only thing I know of that makes it pop of out gear into neutral is dead syncros <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> sorry... that sucks...From what I understand that specific problem is from pulling the shifter out of gear without pushing in the clutch, which you can do, but isnt good for it. Hope this helps.
Old Sep 16, 2002 | 10:07 PM
Dope's Avatar
Got pics of the wiring and stuff around the EGR? Never heard of what you're describing.
Dope
Old Sep 17, 2002 | 01:20 PM
BigRay77's Avatar
what about the surgeing???
Old Sep 17, 2002 | 01:27 PM
Zshark's Avatar
My car does exactly what you are talking about in 3rd gear. We discussed it here:
https://ls1tech.com/ubb/cgi-bin/ulti...c;f=2;t=003890
I dont think that it is the syncros personally because i dont ever grind gears, it just slips out.
Old Sep 17, 2002 | 08:20 PM
wrencher's Avatar
wrencher
For your surging check fuel pressure & check the fuel filter. Does car have alot of mods? This is a surge & not a miss right?
Old Sep 18, 2002 | 02:03 PM
BigRay77's Avatar
wrencher
Member # 6480 posted September 17, 2002 08:20 PM
__________________________________________________ _______________________________
How do i check my fuel pressure? Where is fuel filter? not any more mods than mentioned on the sig....i am pretty sure a surge...what is difference between two?
Old Sep 18, 2002 | 04:21 PM
jimmyblue's Avatar
Moderator
I would settle the EGR question first. It's
a source of mixture error, which can perturb
the fuel computation and result in a hunting
behavior depending on other factors like the
age / cruddiness of the O2 sensors.
There are plenty of ways to make the system
oscillate, I would say start with the obvious
and the cheap, and see what changes the response.
