99 FLPs on a 2001
Old Aug 26, 2002 | 04:15 PM
zGhost's Avatar
Default 99 FLPs on a 2001
All that needs to be done is blocking the EGR on the headers correct?
Old Aug 26, 2002 | 04:31 PM
mmiller's Avatar
Texas Director
Default Re: 99 FLPs on a 2001
You will need to block the EGR, and get a set of shims with a 3/16" dia hole in the middle for the AIR flanges (this is so that the check valves in the AIR system don't get damaged). You will also have to remove the AIR tubing and bend it 90 deg. so that it will match up to the AIR flanges on the headers. Be sure to use the stock manifold gaskets.
Old Aug 26, 2002 | 05:00 PM
xaon's Avatar
I put a set of FLP's from a 98 onto my 01. I didn't want to bend around my AIR tubes, so I purchased new 98-99 (GM PN 12559188 & 12559189) tubes from gmpartsdirect for about 25 bucks each. I also ordered all new gaskets from them as well, since they were really cheap. The guy who I purchased my headers from already had all the emessions equipment blocked off, so I just drilled a small hole in each of the AIR block off plates and bolted it all down. Been running since january with no problems at all.
