Replacement Water Pump Input/Feedback
Old Apr 7, 2006 | 08:14 AM
Hugger Z's Avatar
Default Replacement Water Pump Input/Feedback
So I was diagnosing my powersteering overpressurizing problem last Friday when the water pump let go while we were running the engine. I ended up with coolant all over under the car instead of the powersteering fluid I was expecting. DOH! So now I need a new water pump. It may just be the gasket, but since it is 7 years old, I would prefer to put a new pump on it. One less thing to worry about.
I called around town and there are a bunch of different brands out there. Are any better than others? I want to get one I won't have to worry about as this car is my DD in the warmer months. And I DO NOT want to switch to an electric pump.
Autozone: Valucraft (1yr warranty) or Duralast (lifetime warranty)
Murray's: Fenco (2 yr warranty) or Prestone (lifetime warranty)
Napa: Airtex (lifetime warranty) but no parts available. Would have to be ordered.
Mazza: ASC (1 yr warranty) or A1 Cardone (90 days warranty)
Or I can have a friend get one through GM SPO: AC Delco (no sure of warranty though).
I have had good and bad experience with lifetime warranty parts in the past so I was wondering who has replaced their waterpump and how well the parts have worked.
Are there other brands to try? I looked at Summit and JEGS but only found electric pumps. Do any sponsors make better replacement water pumps? Ported to flow better or anything? I searched but didn't find a whole lot on this subject.
Thanks in advance for any feedback.
Old Apr 7, 2006 | 10:02 AM
REDWS6ROCKET's Avatar
usually our gm stuff is has a very good warranty like 12,000 miles and a couple years i believe.
Old Apr 7, 2006 | 10:45 AM
Hugger Z's Avatar
I think it may carry that same 3 yr 36,000 coverage like a new car. But most dealerships will not advertise that. And if I buy it direct from GM SPO (to get it at cost), how is that warranty handled?
So does everyone still have their stock waterpump and just replace the gasket? When I searched there was a bunch of gasket replacing but not much on the water pump itself. I was hoping for some more feedback on this.
Old Apr 7, 2006 | 11:05 AM
Phate's Avatar
Evans cooling makes a replacement water pump that has a smaller diameter pulley and a larger vane...so it moves more volume. It is also supposed to eliminate the flow discrepancy that the stock pump experiences between cylinder banks.
I have one but have not put it on the car yet, so I can't speak to how well it does or doesn't work. I do know that Darton only recommmends the use of the Evans pump and coolant due to the reasons above.
Get ready to bend over for the $475 or so that it is going to cost, + the custom thermostat and coolant.
Old Apr 10, 2006 | 07:30 AM
Hugger Z's Avatar
Thanks Scott. I looked into the Evans pump, but that is not in the budget at the moment. Based on some local feedback, I think I am going to try to order a Napa replacement pump.
Old Apr 27, 2006 | 04:40 PM
crazymofo1986's Avatar
so whatever pump is fine.... mines leaken do u think i should replace it also since im gonna be there. and how much do they cost?
Old Apr 27, 2006 | 08:57 PM
Hugger Z's Avatar
If it is leaking, that is a sign that it is on it's way out. For some reason these pumps leak before they crap out. Mine was like a deluge under the car when it went. The pumps range in price from ~$150-$180. Look for one with a lifetime warranty. That's what I got. Good luck.
