Thinking of long tubes now... Best bang for the buck.
extenders for the 02 sensors the I suggest
SLP, if you car is lowered then step up
to FLP.. Hookers are nice but I dont think
you get cats and y-pipe.
you can see what comes in the SLP kit here.
http://ls1info.com/modules.php?op=mo...ery&file=index
FLP's work, but go with a custom y-pipe. Their 2.5 inch y SUCKS..
Hookers don't make any more power than Macs.
Dynatechs are an overkill for a 346 motor. Seen a couple of people lose power with them compared to a normal longtube setup..
Grotts would be the best choice. ALL the fast cars in my area run Grotts, and all make excellent power for their mods. Tons of fast cars on this site run Grotts, and also make the dyno #'s to prove the flow of the header. Grott+ custom Y would be the way to go for sure...
Josh
<strong>SLP's have horrible ground clearance and don't make any more power than Macs...
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">werd
I have the Mufflex y-pipe, and although the craftmanship is great, the driver's side pipe bangs on the floorboard with bumps. I'm gonna have to get it welded. Also it has several exhaust leaks where the clamps aren't doing their job. The part where it y's to a single is off center in the driveshaft tunnel, and nothing will clamp onto the 4" outlet because they made it just a little too big.
I'm going to put the juice to the car in the spring and possibly convert to a 427 solid roller. The year after I may add the Pro/Charger or put some more juice to it. No idea yet, but I went with a big header so I can grow into it quickly. I will say on my current setup I am loosing some torque with the big tubes. That should be made up very soon!
Here's what the Grot's did to my Corsa. Simply mean!!
<small>[ August 27, 2002, 08:52 PM: Message edited by: derty ]</small>
Consider the Macs. For $550 bucks i got my headers with off road pipe, installation, 02's etc.
Jason
<small>[ August 27, 2002, 11:28 PM: Message edited by: Jason99T/A ]</small>
<strong>Vince, I went from MACs to Grots. I have a dyno sheet, but I need to scan it in. It was worth ~4rwhp at peak, but the area under the curve was slightly better. This was with my old B1/stock heads setup.
Jason</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Jason, what ypipe did you run ? Stock ypipes on those??
Damian, i see you're point and i respect it so please dont take this the wrong way but um, i'm going to go ahead and have to um.. disagree with you on this one.. um yeah... ;D
what kind of cam specs were these losses on? if you're talking about a straight duration cam (i.e. 222/222), on the stepped 1-7/8" headers, i can see it but, generally you cant go wrong with a larger primary size. however, on a split duration (say, 226/236) the bigger primary i necessicary. Smokey Yunic, Lingenfelter, Pat musi, ect... have been doing this for years.. these seasoned racers know that bigger tube headers make more power N/A, but especially on N20, & SC setups. but it's all in the tuning/ parts combo.
bang for my buck, Dynatech LT's 429 shipped from LS1speed.com, slip collectors (got mine from Stahl headers 49.00 ea shipped) so for cheaper than a set of coated hookers, you get an excellent coated header with no emissions B.S. to boot. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<small>[ August 28, 2002, 01:08 AM: Message edited by: Vents ]</small>
Then you will pick up about 8RWHP peak in street trim vs having to open the cutout <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Cheers,
Chris
