How to recharge my Air Conditioning
Old Aug 28, 2002 | 08:07 PM
SoCal LS1's's Avatar
Default How to recharge my Air Conditioning
Just changed the heads and was wondering how hard it to do this also what to look for and if there where any helpfull tips.
Thanks
David
Old Aug 28, 2002 | 10:39 PM
CMNTMXR57's Avatar
Default Re: How to recharge my Air Conditioning
You can go to your local automotive parts store and pick up a recharge kit. It'll contain a bottle of oil, a bottle of R-134a refridgerant, and a hose that one end fits on the oil and refridgerant bottles and the other to the low pressure side of your A/C system.
First (if necessary) would be to lube the compressor. Usually this is only the case if you have an older car that you are recharging the system because it's depleted it's supply of refridgerant. In your case, you may not need this because you simply opened the system to the atomosphere and yours is a newer car.
Then we move onto recharging it with the refridgerant. Screw the one end of the hose onto the R-134a can, have the car running, turn the A/C onto max and then attach the other end of the hose to the low pressure side fitting. The hose should only fit around this fitting and not the high pressure side (which would blow the can up in your face if you attached it to that). Then screw the handle on the hose that's attached to the can. This punctures a hole in it. Then back it out. This will now allow the refridgerant to flow into the system. Turning the can upside down and tapping on it will help expedite the process. You should start feeling cool air coming out by now.
Now if worse comes to worse, it may be best to take it to an experienced technician as the system may need to be vacuumed and purged clean before the recharging process is done.
Old Aug 28, 2002 | 10:56 PM
thanks for the help how many bottle should it take, i have put three in so far. is this ok?
Old Aug 28, 2002 | 11:29 PM
TA_2001's Avatar
here is a bit of AC data and recharge
info..
http://www.ls1info.com/article.php?sid=233
use a pressure gauge.. $15 at Oriellys.
