Kooks 1 3/4 Stainless Jet-hot Coated with 3 inch Y RANT!!!
I am also having this problem. Banging under the drivers seat has gotten progressively worse. Its when I accellerate from medium to hard, and it bangs from 1st, 2nd, and 3rd. Very annoying as I can't hear my engine anymore, just banging.
I finally finished reinstalling the motor/tranny/rear axle in my car and had the same issues with the new Kooks header/stainless catted y-pipe setup. I had to trim at least 3/4" from the drivers side pipe where it meets the y. I drove the drivers side at least 2 1/2" inches on the header, and the drivers side at least 1 1/2" on the header. I also had to cut two slits in the pipe so it would spread enough to slide on the header. And the outlet of the y where it joins with the catback is still hitting on the passenger side of the driveshaft tunnel. Its also banging on the flattened spot on the drivers side pipe. Pulling it all back out and trying to get everything fixed right now isn't an option. I only get to drive the car ~4 months this year and don't want it down another month waiting for parts. So I'm just going to tuck some industrial high temp fiberglass type insulation in where its touching and hopefully that'll be good enough for this year. I'm just worried about the leverage its going to put on the header bolts...
I'm not trying to hammer on Kooks at all, just letting people know my experiences too.
The weld quality is great, and the headers are awesome, its just that the stainless is harder to tweak to make fit than other metals...
Here"s how I got it right the first time:
1. Loosen up all the clamps on the y-pipe.
2. Stick a crowbar between the y-pipe and floorboard and wrench down to pull the pipe away from the floor.
3. Have a buddy jam a piece of wood in between.
4. Pull the crowbar out and place a floor jack right under where the y-pipe connects together making sure you still have enough access to tighten the clamp in there.
5. Raise the jack slowly until the y-pipe starts to give moderate resistance.
6. Tighten ALL of the clamps on the y-pipe.
7. Lower jack and using the crowbar again remove the piece of wood.
8. Now go drive around and see if it worked.
It seems most aftermarket Y's never seem to fit right and for what they cost vs having one fabbed up right at an exahust shop it's a wonder why people buy mass produced Y's.
http://www.napaonline.com/MasterPage...st+Flex+Tubing
Here"s another solution but in 3" of course. Put this pipe right off the driver side header into the y. Idea courtesy of Sean at CARS in Waterford.
There is also a company that makes these to order in custom sizes. Maybe some kind of bellow like the silicone slp intake belows (but braided steel of course) would work for the catted guys as well. I"ll look into this. Maybe I can get a hold of a company and have 10 or 20 made. If it"s okay with the mods I could sell them here for what I paid for them plus shipping.
Mine still Bangs on the passanger side. For the money I payed i got screwed i think. They should of just sent me another header coated and i would of been happy.
Kyle
Kyle
#33
Originally Posted by Z28XTC
Can this problem still happen with a ORY?
Kooks are known for fitting like gloves. They are human though, and the once in a blue moon not-perfect set will happen. I constantly hear people on here raving about how great their Kooks set-up fits, which is why they are at the top of my list for when I do shell out the cash.
#34
Kyle
Kyle
#35
My Kooks fits like a freakin' glove. Install was not "slide right in", but nothing too hard. Steering knuckle or undo motor mount. But the clearance and Y-pipe fit is absolutely awesome. No banging Y-pipe whatsoever. I did a LOT of research before finally buying my Kooks, and I know George out at Kooks will no doubt take care of ANY ISSUE that you have with any Kooks products.
#36
Banging on the passenger side? I have so much clearance on the passenger side, you could drive a bus through it.....then again, I don't have Kooks, I have Stainless Works headers with 2.5" Y. I am just surprised why there would be any clearance issues on that side.
Manny
Manny
#37
My Kook's 1 7/8 fit fine with no clearance issues with my aftermarket K-Member but I did have to trim the Y-pipe 2 inches where it meets the Catback,,also had to clearance the tunnel a bit so it didn't hit on the passenger floor board.
#38
I love Kooks and would never consider another brand.
I'm that impressed with them.
I have Kooks LT's and ORY the fit is great. When I first installed the y-pipe, it hit in the same two spots as yours. It is infact not adjusted right. Loosen all the clamps on the y-pipe and back off the passenger side off the collector some and it will straighten out and not hit the driveshaft tunnel or trans crossmember.
The passenger side header hitting the k-member is something I've never heard of. All cars have different tolerences and another pair might not fit right either. Maybe try loosening the k member bolts and moving the k member some. It might work.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#40
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I had the same banging problem but with a different header vendor. My problem was that the y-pipe was hitting on my adjustable torque arm as well as the floor.
I got under the car and use a pry bar on the y-pipe to gain about an inch of clearance. I slid in a rexhaust hanger rubber between the y-pipe and the floor board to maintain the clearance.
Then with the rubber exhaust hanger still in-place I installed one of the Mufflex LS1 Y-Pipe "Bump Stop" Hangers that I bought from Thunder Racing. When I had it tight I slide the exhaust rubber out from between the y-pipe and the floor.
Problem fixed and now I'm a happy camper.
