Need help.....fouling 1 plug????
Old Aug 29, 2002 | 06:37 AM
romanss's Avatar
Default Need help.....fouling 1 plug????
I went to Milan to run the car last night. Well the car seemed to be running ok so I went to change over to nitrous mode. When I got to plug #1,it looked like it was in there for 30 years. I changed it again and made a couple more runs and it got black and wet. I swapped the coil pack and plug wire, the problem remained. I think that it might be a stuck fuel injector, but was wondering if anyone would have any other suggestions. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Thanks,
Roman
Old Aug 29, 2002 | 09:30 AM
CHRISPY's Avatar
Default Re: Need help.....fouling 1 plug????
Easy check. Lift the fuel rail, swap that injectors with another and see if the problem follows the injector around <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> That will tell you if the physical injector itself has a problem.
Cheers,
Chris
Old Aug 29, 2002 | 09:45 AM
romanss's Avatar
Thanks Chris,
That was actually going to be the next experiment, tonight. I was just checking to see if there might be something else that I might be overlooking.
Thanks,
Roman
Old Aug 29, 2002 | 11:59 AM
jimmyblue's Avatar
Moderator
Isn't #1 supposed to be the cylinder that's
overbored in cars with the oil consumption
"non-problem"?
Once it's fouled, of course, it just gets
worse with misfire products.
You could check that there's no issue with
spark, just to be sure.
Old Aug 29, 2002 | 08:43 PM
WILWAXU's Avatar
romanss,
How's that monster been? Haven't heard much from you in a while...
Old Sep 1, 2002 | 08:10 PM
romanss's Avatar
WILWAXU, The car doin ok. I think that I smoked a ring or 2. So off comes the head tomorrow. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
How's your ride going?
Old Sep 4, 2002 | 04:17 PM
WILWAXU's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by romanss:
<strong>WILWAXU, The car doin ok. I think that I smoked a ring or 2. So off comes the head tomorrow. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
How's your ride going?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Still stock internals <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> Haven't really heard much about your car lately (I use to run the all fastest list on LS1.com).
