RandomTech cats with Hooker Y pipe?
Old Aug 29, 2002 | 09:07 AM
Torqued's Avatar
Default RandomTech cats with Hooker Y pipe?
Has anyone installed the RT bullet cats into the Hooker ORP y-pipe? Or does a completely new y pipe need to be fabricated from scratch to use cats?
Thanks
Old Sep 4, 2002 | 04:05 PM
WILWAXU's Avatar
Default Re: RandomTech cats with Hooker Y pipe?
ttt
Old Sep 4, 2002 | 08:52 PM
Torqued's Avatar
We'll I think it can be done and will try shortly. RandomTech has two 3" compact cats which have an OD of 4". One is pelletized and flows around 440cfm@28. Another one which is new, is a 'metallic' cat and flows around 560cfm@28. This one is shorter however it costs about $75 more. I plan to install a single cat just after the y.
The header install was easy using jack stands but pretty time consuming. Removing and reinstalling the #8 plug and wire was the most difficult part of the installation. I am surprised how quiet the car is with the ORP and Dynomax RaceWeld muffler. No drone while cruising and very quiet at idle.
<small>[ September 06, 2002, 05:51 PM: Message edited by: Torqued ]</small>
Old Sep 4, 2002 | 09:05 PM
XLR8NSS's Avatar
Adkoonerstrator
Here is a pic of one of the new 3" cats that flows 560cfm.....and yes it is short. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
https://ls1tech.com/ubb/ultimatebb.p...;f=24;t=003275
John
Old Sep 4, 2002 | 09:09 PM
Torqued's Avatar
Damn. Thanks for the picture and helping decide which cat to go with <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Sep 27, 2002 | 03:51 PM
Torqued's Avatar
Well the answer is YES. I just had the cats mentioned above installed in the Hooker ORP. I recommend that the work be done by a good referred mechanic. I still have 3" of ground clearance. I believe that the car is quieter now with this setup than with the factory setup (or maybe the WOT runs with ORP caused some hearing loss <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> ) . Now its time to run the car on a wide band and make some adjustments.
I don't have any pictures however if somebody in the metro Atlanta area has a digital camera and a friend with access to a lift...
