Pacesetter Header Install
Old Apr 8, 2006 | 01:57 AM
radcliffe18's Avatar
Default Pacesetter Header Install
Today after school i decided to put my headers and y-pipe on, after 7 hours of bangin my hand in tight corners and about 200 cuss words, i got the last bolt tight, i cut one of my plug wires so i dont even get to start it up or drive it til tomorrow if your puttin pacesetter headers on, here are a couple tips, you need to grind about 1/2 off a square tab on the block, and you do not need to take off the passenger side spark plugs, that'll save you some time, if anyone has any questions on installin headers i'll answer them
Old Apr 8, 2006 | 05:53 AM
Juiced2000SS's Avatar
I just installed mine last Sunday and didn't need to grind the block. The header got stuck there but I pushed a little harder and it went past. They really are some of the easiest headers to install. You'll love the new sound from your car.
Old Apr 8, 2006 | 06:52 AM
Raise's Avatar
i didnt need to grind the block either when i installed them on my 02 z28. had to bang on the body a tad on the drivers side but then they slid right in. 4 hours tops. ill probably be buying them for my 02 ss as well.
Old Apr 8, 2006 | 07:24 AM
NVR KNO's Avatar
i never had to grind the block on mine either. i have a 99 ss. it took me and my roommate 4hrs of actually working to take the old stuff off and put my headers and y-pipe on. very easy install and sound great. i luv them.
Old Apr 8, 2006 | 10:04 AM
Fratsit's Avatar
I've got a pair of JetHot LT's and a Mufflex ORY waiting to install. Just waiting on my O2 sims.
Brown cant get here fast enough....
Old Apr 8, 2006 | 11:08 AM
Beasst8's Avatar
I agree, never had any grinding. Fitment was nothing less than perfect for lack of a better word.
Old Apr 8, 2006 | 12:19 PM
2K2WS6TA's Avatar
Well every car is different it seems, I'm doing a second install for a buddy, and his car has fought me every inch of the way.
The passenger side was a PITA to take the stock manifolds off, and the drivers side is a PITA to put the header on.
Contrast that with my own install, it was a breeze, the headers practically flew up into position, so it seems every car has its differences
Old Apr 8, 2006 | 01:20 PM
iamsickofitall's Avatar
mine popped right in...i left the spark plugs in on both sides for the install - they didn't get in the way once
Old Apr 8, 2006 | 02:12 PM
slt200mph's Avatar
When I did mine I had no problem fitting them to the car..my girl friend had to lay under the car and hold them up or they would fall out on the floor when I bolted them on..no grinding or banging very EZ to install...
Old Apr 8, 2006 | 02:17 PM
Slow00ls1T/a's Avatar
Ya mine went right in didnt haveto grind tat all the driverside we had to move the engine over with a prybar like a inch but other then that it was peace a cake
Old Apr 8, 2006 | 07:12 PM
Beasst8's Avatar
Yes, every install is different. Now that I think bout what I said before, they went in easy, but to this day, the factory manifolds and cats are still together. Could not get them apart to save my life. Oh well.
Old Apr 8, 2006 | 11:19 PM
SLPSS01's Avatar
same here no grinding left plugs in on both sides they slid right in.
Sorry I gotta ask how did you manage to cut a spark plug wire ? -lol
Old Apr 8, 2006 | 11:38 PM
greddyt56's Avatar
do you have to get a tune for pacesetter LT's and an offroad y pipe?
Old Apr 8, 2006 | 11:47 PM
brad8266's Avatar
A tune helps, not needed though.
Old Apr 9, 2006 | 11:12 PM
they say with headers and ory pipe that you'll run a little rich, that would be the only reason for a tune is the adjust your air/fuel ratio, and to get that SES light off, the car sounds so damn mean, like it would rip ur arm off and beat you with it, when you are WOT it sounds nothin less then a race car, when i hammer on it around town i have people callin me all the time asking if that was me, i cut the wire cuz it was the passenger side back plug wire and i couldnt get it off about 30 minutes of wigglin and pullin, so i used pairof pliers and forced it out
Old Apr 10, 2006 | 08:07 AM
slt200mph's Avatar
A tune will insure that you get all of the horsepower that you bought when you got your headers. You are leaving at lest 10 HP on the table if you do not get a tune. These cars all run rich with the factory tune on them...
Old Apr 11, 2006 | 12:07 AM
2002ssls1's Avatar
How high does the car need to be off of the ground to do a header install on an 02ss?
Old Apr 11, 2006 | 08:18 AM
slt200mph's Avatar
I drove mine up on some rhino ramps and did the install...
Old May 1, 2006 | 01:31 PM
JoeZLS1's Avatar
Just installed Pacesetter LT's on LS1. Had front up about a foot and a half in air and rear maybe 6 in. Drivers side was a biotch to get in. Had to kinda man handle it past the block but it worked. Prob scratched the header a little but I had no choice. That is the only problem I had aside from my hands hurting because of trying to fit them into all these tight spots to take off and resecure bolts. Didn't replace spark plugs. I though would probably recommend getting new spark plug wires cause those things were very loose after i reattached them. With the engine shake it kinda rattles them off. I gotta get some tighter (new) ones.
Old May 1, 2006 | 02:07 PM
lowchevy2go's Avatar
i didnt grind tab, i got the car as high as i could on jackstands and got a jack with a block of wood and started to jack up on the oil pan. It lifted the side od the motor just enough to get the header in. Gotta be careful notto jack on it to much or the car will lift off the stands and prolly squish you.
