Best Induction Setup?
Old Sep 13, 2002 | 11:42 PM
ss1le02's Avatar
Default Re: Best Induction Setup?
The FRA mod is just cutting the box where the filter sits. You do not have to cut the radiator shrouds. It is very simple to remove the shrouds. All you need is a screwdriver to remove the bottom 3 clips, and a 10mm socket and ratchet for the 2 bolts on the bottom shroud. For the top shroud you just have to seperate the 4 clips/snaps and pull it out when you are doing the FRA on the filter tray. This will make the installation of the Supersucker that much faster. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
