how do i tighten the belt?
Old Apr 9, 2006 | 12:46 PM
goodrich969's Avatar
Default how do i tighten the belt?
im trying to tighten my serpentine belt so it dosent squeal.. how do i do it?
Old Apr 9, 2006 | 12:48 PM
Quickin's Avatar
You don't. Unless you have a Katech tensioner.
Old Apr 9, 2006 | 12:52 PM
ive had like 3 ppl tell me to tighten it up.. ive never heard of a katech tensioner
Old Apr 9, 2006 | 01:08 PM
Quickin's Avatar
It's just a spring tensioner if its stock. I have a Katech tensioner that allows tightening, it also keeps the belt from coming off under acceleration which happens with stock tensioners.
Its a great replacement piece:
http://www.katechengines.com/street_...etail.php?id=1
Old Apr 9, 2006 | 01:20 PM
cant i just get a stock replacement form a GM dealer, wouldnt that stop the noise
Old Apr 9, 2006 | 02:15 PM
ttt...
Old Apr 9, 2006 | 02:52 PM
Quickin's Avatar
Don't just go buy a tensioner thinking that the noise is coming from that. I bought two pulleys and found out it was my compressor.
Unless you know for certain its the tensioner thats squealing, yes, you can just go buy a new one.
Take the serpintine off and spin the other stuff with your hand to see if you hear a squeaker. If not, than take the compressor belt off and put the serpintine back on, start it up and listen to rule out the A/C compressor and its 2 pulleys.
Old Apr 9, 2006 | 03:11 PM
TS6's Avatar
TS6
And stop listening to those 3 people, they are idiots.
Old Apr 9, 2006 | 04:57 PM
Shallow Bay's Avatar
Originally Posted by Quickin
Don't just go buy a tensioner thinking that the noise is coming from. I bought two pulleys and found out it was my compressor.
I did the exact same thing.
Old Apr 9, 2006 | 05:12 PM
sleeperstyle's Avatar
my idler pulley was squealing/chirping for a while. immediately thought it was the belt till i listened really close- sprayed it with silicone grease/spray for a quick fix and bought another idler soon thereafter. the idler pulley could be hanging up, like the bearings are worn and it doesn't spin freely. that would cause the belt to slip over it and squeel.
if not you probably need a new belt/tensioner.
Old Apr 9, 2006 | 05:38 PM
daryl2cb@yahoo.com's Avatar
you can also remove the ac belt, to help better locate your issue. This will pinpoint where the noise it coming from, ie motor or a/c drive.
Old Apr 9, 2006 | 06:49 PM
jdaniels's Avatar
Mine was squealing horribly, I put a new Dayco belt on there and the noise stopped.
Old Apr 9, 2006 | 10:33 PM
TheBlurLS1's Avatar
That's what she said...
"yuh just ned to tiorghten teh belt on dat dar tree-fidy"
Got many people like this around?
Tell them we have an automatic belt tensioner, that'll get them thinking! I agree with removing the main belt and trying to isolate the problem. There is also another belt for the a/c compressor down there. That belt runs over another idler, another spring tensioner, and the bastardly a/c compressor. If it is doing it, you remove the main belt and it stops, you knock out the a/c system as a source of problems, and vice-versa.
Sometimes belts get so old, the tensioner can't keep it tight enough to not squeal.
Funny story - After my cam install, i went to HPE and pulled it into the shop for tuning. Everyone was telling me how nice it sounded (dumped duals, cammin ***** w/ no tune lol). They were having a GTO dynoday, so there were alot of people there too. Not 3 minutes after some guy told me how good it sounded, the belt area started SCREAMING! I thought i was due to just a new belt, new pully, or something, but later i tracked it down to the idler pulley. The bolt holding it on was about 2 turns away from falling off. Kinda scary considering i had to drive 2 hours to get to HPE. I tightened it up and it was good to go.
Old Apr 10, 2006 | 12:03 AM
Quickin's Avatar
Get a Katech tensioner. This solves so many problems.
Old Apr 11, 2006 | 12:49 AM
WILWAXU's Avatar
Untill is gets wet the first time and starts squeaking too.
Old Apr 11, 2006 | 12:58 AM
toofless916's Avatar
i have a belt that squeels only in the morning when there is moisture in the air..like if it was raining the night before....i cant stand it!
