Descreening MAF will it hurt my car
Old Sep 8, 2002 | 07:02 AM
00_TA_WS6's Avatar
Default Descreening MAF will it hurt my car
I was reading around and people were talking about taking the screens out of their MAFs. Will this mod hurt my car or throw anything off.Does anyone know how well this works??
aaron
Old Sep 8, 2002 | 07:17 AM
Raughammer's Avatar
D(irecto)r Pepper
Default Re: Descreening MAF will it hurt my car
The car will most likely run leaner...
The car will most likely pick up a few degrees of timing....so you'll need to cool it off more to avoid detonation.
Usually it is worth a few ponies to remove the screen.
Ported ends or home porting the MAF is also an option, and is highly recommended by most folks for the 98-99's.
If it is a 00,01,02 A4, with their less than agressive tranny programming...it is not advised to do. (porting the MAF, that is)
But descreening? by all means, do it.
Mucho free mod info is available on my web page.
Old Sep 8, 2002 | 08:30 AM
mike c.'s Avatar
i used thunder racing hiflow ends and went from 13.12 to 12.96, not bad for the money.get a 160 t.stat too.
Old Sep 8, 2002 | 02:09 PM
99 Black Bird T/A's Avatar
GM put the screen there to straighten and smooth air flow. This was an issue on the older LT1's because their air intake systems didn't have a straight shot like LS1's do. GM later got rid of the screen on 02 LS6. I don't think it will hurt as per the other posts.
However, I have seen very badly fitting lids, etc allow bugs to get sucked in and the screen will usually catch the bug. A big bug could break a MAF wire if it hit it and wouldn't be good for the engine. Might have a little use as bug guard if the intake track is in poor condition.
As long as everthing fits well shouldn't be a problem.
Old Sep 8, 2002 | 04:29 PM
uLoSeAgAin's Avatar
I have a 99 trans am and my lid doesnt seal well and it aloows bugs and crap to get in and my screen cathes it. What would be recommened to seal off my slp lid? Also whats the deal with the proting and ends....would I run rich and would a 160 thermo help out?
Old Sep 8, 2002 | 05:50 PM
BensZ28's Avatar
as long as the lid fascens relatively tight, Im sure you could use any kind of small foam lining to get inbetween the seals, or you could try and home make a kind of rubber gasket out of a sheet of latex. Ive never tried either of these...just sounds like it should do the job
<img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" />
Old Sep 8, 2002 | 06:33 PM
DONAIMIAN's Avatar
if the air box bugs you (no pun intended) the use duck tape <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Sep 15, 2002 | 10:50 AM
uLoSeAgAin's Avatar
Can anyone explain exactly how and where to place the duck tape or foam in the lid to make it seal better?
