OMG!!!! Major backfiring after header install
Old Sep 9, 2002 | 07:57 PM
LOnSLO's Avatar
Default OMG!!!! Major backfiring after header install
Just finished installing LT's and took the car out for a shake down run. When i hit it, I get major backfiring. Doesn't matter if I'm running slow or at WOT. WTF is going on?!?!?!?! I reset the PCM twice, and it's still there. HELP MEEEEEE!
Old Sep 9, 2002 | 08:05 PM
11 Bravo's Avatar
Default Re: OMG!!!! Major backfiring after header install
What plugs do you have? What are they gapped at? What is your a/f?
Old Sep 9, 2002 | 08:18 PM
wrencher's Avatar
wrencher
Any cracked plugs? loose wires?
Old Sep 9, 2002 | 08:38 PM
LOnSLO's Avatar
Just put in TR55's. Left them at their stock gap. Don't know my A/F ratio, but could I be so lean that the car won't hardly run or what?
Old Sep 9, 2002 | 09:13 PM
MY99TAWS6's Avatar
More like car is super rich I think and unburned fuel ignites in the pipes..did you put the whole catback and ypipe system on or just open headers..
did you put 02 sensors in.I drove my car to midas and had them install the cats/ypipe and my new cutout and quick time controller..it ran just terrible all the way there..it was way the heck out of tune..my headers made the car very rich at
wot..a bit lean at idle.I had my maft dialed like 5 clicks down to compensate and now have it like two clicks down and am trying to use my hpp non rfg tuning to lean it out and add some spark advance.
Old Sep 9, 2002 | 10:00 PM
LOnSLO's Avatar
Just put on the headers, and left the SLP factory dual-dual exhaust. Could it be the plugs?
Old Sep 9, 2002 | 10:07 PM
Slowhawk's Avatar
LS1Tech Sponsor
Sounds like it's running real rich with an exhaust leak to pull fresh air in to ignite <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Sep 10, 2002 | 02:00 PM
MY99TAWS6's Avatar
Well I am down like four clicks now on my maft and have my non rfg tuning in..car seems to be running much stronger faster and no significant knock retard to speak of..did run my slp fan switch and kept temps at 175 degrees..might just program the hpp to be permanently at the 160 setting but this way I leave hpp at 180 or even 195 and then fire on fans when I want it cooler.this works better when we get cold in october or april..don't drive the car in winter.
So I am sure you are real rich with those headers.
Old Sep 10, 2002 | 08:12 PM
LOnSLO's Avatar
I checked all plugs, and that wasn't the problem. Put stock MAF back on, still no dice. Heard some sort of clicking noise under driver's side header, but couldn't locate it. Didn't hear any noise from the top. It's running so bad, I'm scared to drive it. Any other suggestions? Do I need to fab some AIR restrictors?
Old Sep 10, 2002 | 08:18 PM
wrencher's Avatar
wrencher
Clicking noise drivers side header sound either like a plug wire arcing out or a exhaust leak.
Old Sep 10, 2002 | 08:39 PM
DaddySS's Avatar
Are you sure you don't have some wires crossed?
Old Sep 10, 2002 | 10:01 PM
LOnSLO's Avatar
Definitely don't have any crossed wires. It idles okay, but at part throttle and WOT, it sounds like the 4th of July.
Old Sep 10, 2002 | 10:10 PM
LOnSLO's Avatar
Forgot to add. SES light began blinking while taking it around the block. It stopped after about a minute. Does this mean the code is gone?
Old Sep 11, 2002 | 03:43 AM
ls1snakebiter's Avatar
yes i had long tubes on my car and mine done the same thing. wouldnt run for ****.... my problem was when they put the header in there they cracked 2 plugs on the passanger side. it was missing and sputtering real bad. Get ahold of someone and have it put on a computer and check each cylinder to see if it is firing. They found out it was the 2 plugs poped some new ones in and in ran good. No matter what u do u will always get the ses light to pop up everyonce in awhile. Thats because i wasnt running cats on mine and wit out cats sounded terrible got me a set of cats and it sounded good then.
Old Sep 11, 2002 | 05:23 AM
DARK AGE 53's Avatar
Like other's have said it's a good chance it's a plug or plugs cracked, plug wire or wires have been broken. An easy way to check what the clicking sound is would be to remove one plug wire at a time from the coil pack ( if there's no change reinstall the wire ), if the clicking goes away you've found your problem ( bad plug or plug wire ). You could have more then one bad plug or wire so listen if the sound goes away or lessens. Good luck and keep us updated.
Al
Old Sep 11, 2002 | 07:34 AM
LOnSLO's Avatar
I'm thinking it's a faulty plug wire or two. I'm getting new wires today, and will try that. If that's not it, I'm going to freak! My hands look like they went through a meat grinder.
Old Sep 11, 2002 | 07:47 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by LOnSLO:
<strong>I checked all plugs, and that wasn't the problem. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">How did you check the plugs, if you just pulled on the plugs to see if they were broke that might be not be enough. You could have a small crack in the porclien on one or more of the plugs, again good luck.
Old Sep 11, 2002 | 08:17 AM
LOnSLO's Avatar
I thoroughly checked the plugs. No cracks. The tip was almost solid white however, possibly due to a lean condition. They are brand new plugs.
Old Sep 11, 2002 | 08:35 AM
Slowhawk's Avatar
LS1Tech Sponsor
Did you install a SLP fan switch at the same time?A friend of mine did when he did his headers and it ended up being the switch setup.Would misfire the driver side bank.
Just a thought.
Old Sep 11, 2002 | 08:50 AM
LOnSLO's Avatar
Nope, just changed the plugs.
