Need help with ASP pulleys
Old Sep 10, 2002 | 09:18 PM
CashDudeHomie's Avatar
Default Re: Need help with ASP pulleys
Thanks for the help everybody!!! <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
Old Sep 11, 2002 | 12:57 AM
Default Need help with ASP pulleys
I have never done a crank pulley swap so if someone could post some pretty detailed instructions, that would be great. Thanks.
Old Sep 11, 2002 | 04:25 PM
MY99TAWS6's Avatar
I think the problem is haven't seen any pics of one..its pretty easy and if you get one new they come with instructions from asp..its easier to do with car in the air.I did mine at midas..they do a lot of custom work for me ..you need a proper three jaw puller..you have to grab the stock pulley from these little tabs..forget the exact length.and getting a longer bolt and some washers in the same thread as the stocker can be handy also.You just take it off..and then you reinstall..and torque to like 250 ft pounds with the old bolt and then 37 I think it was with the new bolt and then something about 120 degrees after that..can get a torque angle meter or just wing it..thats it..you don't resuse old bolt they are torque to yield..also put some loctite on the bolt..I never did find any pics or site with install.
Old Sep 11, 2002 | 04:43 PM
Benjamin Russick's Avatar
Go to this link and check it out.
http://www.geocities.com/scott2049/pulley.html
I have to do this mod soon myself, so any other input would be cool.
