MAF Suggestions....Is it the cause of my detonation?
Old Sep 15, 2002 | 06:12 PM
MattG's Avatar
Default MAF Suggestions....Is it the cause of my detonation?
I have had quite a few issues with WOT inaudible detonation between 4000-5500rpm as well as audbible knock at lower RPM part throttle.. If I come around a corner at 2000rpm in 2nd and lightly touch the gas pedal to accelerate out of it, I can easily hear and feel the detonation. If I am driving one speed and push my foot to the floor it will ping a buncha times as well before I take it the PCM backs the timing off enough that it goes away...
I have done the PCV mod and do not feel this is the cause of it..
I have played around quite a bit with the timing in LS1Edit and cannot get rid of it.
I have come to the conclusion that it may be my MAF sensor that is causing it.. I am running the SLP Big MAF.. I had it on my car when I had my heads/cam and there were no problems.. Ever since the 436ci install, this detonation has started.. I believe this was one of the earlier SLP MAFs and I replaced the smaller 97 stock one with it..
There is a resistor that SLP puts in this MAF to richen the car up a bit correct? Should I remove it? Should I just get a new LS6 MAF? I imagine I will have to retune the whole car pretty much if I do replace it, but I am on a definite mission to get rid of this damn detonation!
Any suggestions?
Thanks in advance.
Old Sep 15, 2002 | 08:29 PM
new-LS1's Avatar
Default Re: MAF Suggestions....Is it the cause of my detonation?
Join the club <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> I have the same problem with mine. Just tap the gas pedal slightly at 2000 RPM's and there you have it "PING" <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> Im thinging it's because im running really hot. 215+ degrees on the temp gauge. Im hoping a 160 t-stat will help cure this problem. Good luck.
Old Sep 15, 2002 | 09:34 PM
Sears's Avatar
!Dial-up Director
What is the compression ratio on that 436ci motor? What octane gas are you running?
Justin
Old Sep 15, 2002 | 09:47 PM
sited12's Avatar
If the MAF has something on it to richen up the car then that isnt causing detonation. You are running to lean then. Check the air/fuel with atap and go from there.
Old Sep 15, 2002 | 10:03 PM
MattG's Avatar
The CR of the motor is 11.5 and it never see's less than Sunoco Ultra 94.. I was running the strongest NOS octane boost for quite awhile and it didnt improve anything either.
My fuel pressure is normal. My LTRIMS all average around -5, my car pulls a 12.7 AFR at WOT on a dyno. I do have the stock T-stat in the car but with my heavy duty radiator and oil cooler my coolant never goes over 205 degrees. I have a 172 T-stat that I may try.
Old Sep 24, 2002 | 10:02 AM
Bandit's Avatar
I just bought a 00' ram Air M6. I got a little detenation at high rpms. I was going to take it in and have it looked at but I tried switching MAF sensors with my 02 and I think it went away. The M6 is so loud under WOT it's kind of hard to tell if it is or isn't now. I'm also going to put in a 160 thermostat just because it helped the 02 run a little rich.
As for the 00' MAF on the 02', no detenation at all. Go figure???
