Questions about drilling the Throttle Body
#2. Depends on the year. Most can go to 650 w/o any problems, some can go 700 rpm or higher w/o a code.
#3. Not sure the minimum, but 750 will work with a good lope.
#4. Probably not.
#1 How much does this raise the idle?
#2 If it raises it more than 100 RPM's doesn't that throw a code?
#3 I've got a 3000 Vig Converter now.What RPM does this cam need to idle at without stalling?
#4 If I drill the hole bigger ,then get the PCM tuned later ,will I need to close up the hole again?
